1998 Toyota Camry COIL THAT SITS ON TOP OF SPARKPLUGS 2,4 A
1998 TOYOTA CAMRY
90,000 MILES • 6 CYL • FWD • AUTOMATIC
WILSONJ3
I have been experiencing a rough idle. Some times it's not as rough as other times. I was told that all the cylinders were not firing properly and that I probably need a tune up. I have replaced the spark plugs and wires. I have replaced the air filter and checked for vaccum leaks. I am comtiplating on changing the coils but they are so exspensive. Is there a way that I can test the coils that I have on the car now?
Thanks
J
Jun 17, 2008 at 3:48 AM
BLACKOP555
  • 10,386 POSTS
call around to local auto part stores and ask if they will test them for you.
if you cant find any let me know and i can explain it to you...
Jun 17, 2008 at 6:08 AM
