1998 Toyota Camry catalytic converter?
1998 TOYOTA CAMRY
14,000 MILES • 4 CYL • FWD • AUTOMATIC
DARBY_ODELI
I had my car tuned up, and was told excessive rroad noise was from worn tires. replaced the tires, but still getting horrible noise, and it is getting worse. The noise level seems to adjust to certain speeds but is at it's worst between 55 & 60 mph, when it is unbarable and is even louder in the back seat. There is no exhaust smell inside tha car, but the floorboards do heat up quite a bit, and the car doesn't seem to be any louder when heard from the outside (as it is driving up the road). Any suggestions, and how much should I expect to pay for repair for the problem? Even a basic "guesstimate" would be helpful. Thank you.
May 29, 2008 at 2:56 PM
LEGITIMATE007
  • 5,121 POSTS
sounds like the hub assembly(wheel bearings) in one of the rear wheels is bad. as far as repair, for one side I would guess about 200 dollars more or less
May 29, 2008 at 4:39 PM
