1998 Toyota Camry Bump stops
1998 TOYOTA CAMRY
250,000 MILES • 4 CYL • FWD • AUTOMATIC
HELOTES
  • 7 POSTS
What will happen if my vehicle has no strut bump stops? Are they necessary?
May 26, 2010 at 4:24 AM
  • 31,937 POSTS
Hi there,
thank you for the donation,
The bump stops cushion out excessive suspension movement, if the suspension hit full travel it will strike the bump stop and this will ease any shock loading and noise, with out them, you would get some noise and a bit more noise and a harder bottom out knock, under normal driving conditions you normally never reach this point in suspension travel.
Mark (mhpautos)
May 26, 2010 at 7:29 PM
