1998 Toyota Camry brake lights out
AKAMU
Brakes problem
1998 Toyota Camry 4 cyl 144k p miles
when I start my car and put in gear there's a dummy light on the dash indicating a brake light malfunction and sure enough I have no brake lights. I check the fuse it's okay try to check for brake light actuator but located none. the bulbs are good. can you help?
Jan 20, 2008 at 6:14 PM
  • 31,937 POSTS
Hi there,
The brake light switch is mounted on the pedal arm under the dash.
Mark (mhpautos)
Jan 20, 2008 at 7:06 PM
