1998 Toyota Camry Brake Light
168,000 MILES • 4 CYL • FWD • AUTOMATIC
MCPHD
Last week, my brake light started coming on in the morning time once I start driving. It would stay on for a brief moment and then it would go off. What could be the reason?
Oct 4, 2010 at 9:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you mean the brake warning light in dashboard? if so than check brake fluid level.
Oct 4, 2010 at 9:49 AM
MCPHD
Yes, it's the brake warning light on the dashboard. I forgot to mention that I checked the brake fluid and it is on the full level.
Oct 4, 2010 at 9:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
since fluid is full then most likely the brake pads are worn out and need replacing, inspect the pads thicknesses.
Oct 4, 2010 at 10:03 AM
