Electrical problem
1998 Toyota Camry 4 cyl Front Wheel Drive Automatic 96K miles
My car sometimes hestitates to start up. After it warms up it usually will not hesitate again until the morninng. I took the negative cable off overnight to see if that stopped any potential draining and it seems to have, but recently I put it back on and it worked for several days but is now hesitating from time to time. The garage I took it to said the battery was bad an replaced it. Same problem. I put an ammeter in series with the neg post and the removed cable and it appears that there is a reading. I get an irratic reading--could be my meter. Any ideas?
Mar 8, 2009 at 12:07 PM
