1998 Toyota Camry axles
WILLIE99999
Drive Train Axles Bearings problem
1998 Toyota Camry 4 cyl Two Wheel Drive Automatic
How do I pull out the passenger side axel (out of the carrier bearing)
May 26, 2008 at 3:06 AM
MERLIN2021
  • 17,250 POSTS
You'll need a socket large enough to remove the axle nut, and a tool to break the ball joint free. Then just pull the strut rotor and all outward until the cv-joint clears the knuckle, I would change the whole shaft, Reanufactured axles are pretty cheap, and it's quicker and easier than messing with seperating the old joint! Use a bucket under the inner joint to catch any tranny fluid that might leak out! If you have trouble with the inboard joint, use to large flat blade screwdrivers, or prybars and pop it out of the differential...
Toyota says to disconnect the tie rod and remove the fender apron and seal as well, and drain the tranny first.
May 26, 2008 at 3:18 AM
