1998 Toyota Camry 3 Warning lights are on or blink at same
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLASCWIL
ABS Warning light stays on. Traction Control Warning light blinks. Battery discharge warning light stays on at idle, blinks while driving
Dec 23, 2008 at 5:40 AM
ZACKMAN
  • 4,202 POSTS
For ABS and traction control, you need to go to a place that has a scan tool capable of scanning ABS. Autozone and CSK/O'Reilly scanners don't have this function.
Battery light: First, check the tension on the serpentine belt. If the tension is right, then go get your electrical system checked. Autozone or CSK/O'Reilly will be able to do it.
Dec 23, 2008 at 6:19 PM
