1998 Toyota Camry
FREDMACE
Engine Mechanical problem
1998 Toyota Camry 4 cyl Automatic 210000 miles
Toyota Camry 1998 LE 4 cylinder - I'm replacing the oil pan gasket. Visual inspection show at least 1 screw, at the rear of the pan, under the oil pan insulator, the other, in the opposite side, is visible but not of easy access. Do I need to remove the front exhaust pipe? Do I need to remove the stiffer plate to access these 2 pan screws?
Aug 13, 2010 at 2:00 AM
MMPRINCE4000
  • 8,548 POSTS
You will need to remove front exhaut pipe and loosen motor mounts to lift engine for clearence.
Aug 13, 2010 at 2:18 AM
