1998 Toyota Camry Electrical Failure
UKROY
1998, 4cylinder, 100K+ miles. Engine starts and runs, headlights turn on but everyting else is dead, including rear lights. Will not shift into drive unless I push the hidden over ride button. Drove it to work as is, then 15 mins into journey, everyhing came on slowly, including engine check light. What would cause this?. Now alarm system operating, therefore immobilized until I can use transponder (At home of course!).
Sep 19, 2007 at 4:17 AM
BMRFIXIT
  • 19,053 POSTS
[quote:d1c5acaebe="ukroy"]1998, 4cylinder, 100K+ miles. Engine starts and runs, headlights turn on but everyting else is dead, including rear lights. Will not shift into drive unless I push the hidden over ride button. Drove it to work as is, then 15 mins into journey, everyhing came on slowly, including engine check light. What would cause this?. Now alarm system operating, therefore immobilized until I can use transponder (At home of course!).[/quote:d1c5acaebe]
checked fuses yet
not been able to shift
no brake light check to see if you have power on the brake switch
also you may have an alternator problem
good luck
Sep 19, 2007 at 12:44 PM
UKROY
System now back to normal!!. I reseated all the relays, reset the alarm and everything OK except for check engine light was on. Drove about 25 miles and now check engine light off.
Thanks for suggestions
Sep 19, 2007 at 11:56 PM
Suggested Repair
Check the fuses and power at the brake-light switch, since lack of brake-switch power can prevent shifting out of park. Also inspect the alternator and reseat the relays; resetting the alarm may restore normal operation.
Conversation Summary
A 1998 Toyota Camry started and ran with headlights working, but most other electrical functions, including the rear lights, were dead and the shifter required the override button. After about 15 minutes, the systems gradually returned and the check-engine light came on; the alarm then immobilized the car. The expert suggested checking fuses, brake-switch power, and the alternator. The owner reseated the relays and reset the alarm, after which everything returned to normal and the check-engine light later went off.
