1997 Toyota Camry starting
GREASER
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 100,000 MILES
Unpredictably, the engine cranks & starts but immediately the rpm drops and dies. Occurs usually when the engine has been turned off for 2/3 hours.
Starts fine in the morining when its really cold.
Can it possibly be related to the starter since it is very old?
Can it be IVC valve & how likely?
Can it be fuel injection? (The engine runs smooth & never hesitates when running.)
Wednesday, July 9th, 2008 AT 4:10 PM
Check the fuel pressure to rule out the fuel pump/pressure regulator/fuel filter-then the idle air control valve and EGR valve.
There's nothing wrong with the starter-its doing its job
Wednesday, July 9th, 2008 AT 4:26 PM
