1997 Toyota Camry Signal & Tail Lights Flicker for no r
1997 TOYOTA CAMRY
264,000 MILES • 4 CYL • FWD • AUTOMATIC
TKLEE1
  • 7 POSTS
Toyota Camry 1997 LE
Just bought this car used:
Tail lights and signal lights turn on and off while driving, when first starting and when A/C is on full blast. i hear a clickin sound in the dash while the lights turn on and off.
At times when I am getting out of the car, and I turn off the headlights, the signal lights and tail lights will not turn off. Sometimes it takes restarting the car , turning the headlights on and off several times, just so the signal and tail lights will finally turn off.
My battery is good, but I took it to AutoZone, and they determined that it has a hole in it. They said that could cause the problem.
Also, I'm not sure if the alarm system on the car is factory or aftermarket. Either way, I don't have the keyless entry remote.
Apr 17, 2009 at 2:09 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect an after market security system
check driver side under steering area for the alarm box
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 17, 2009 at 2:17 PM
