1997 Toyota Camry Seat Belt
135,000 MILES • 6 CYL • FWD • AUTOMATIC
JHURST
The right rear passenger seat belt is fully extented and will not retract. I would like to known how to release the lock so the seat belt will retract. Is this a part defect and the seat belt needs to be replaced.
Dec 30, 2007 at 10:08 AM
  • 31,937 POSTS
Hi there,
if the seat belt is fully extended and locked, i would remove the sat belt and rotate the housing while gently pulling on the belt, the locking lever and spring, is stuck, if it won't release easily, get a new belt, you don't want to be messing with seat belts and lives, if it is at all suspect and defective, the other belts should be fine.
Mark (mhpautos)
Dec 30, 2007 at 5:55 PM
