1997 Toyota Camry replacing plug wire and plug
235,000 MILES • 4 CYL • FWD • AUTOMATIC
NIKHIL_424
hello sir
i replaced plug wire and plug but when i was replacing wire i did mistake which wire going where.that was my mistake so how i know which one is wright
this is like map
Nov 17, 2008 at 10:26 AM
ZACKMAN
  • 4,202 POSTS
Firing order 1-3-4-2. Cylinder 1 is the closest to the belts, then cyl 2, 3, and 4 will be the closest to the flywheel.
It is a DIS distributorless ignition system, cyl 1 and 4 share the same coil, cyl 2 and 3 share the other coil.
Nov 17, 2008 at 3:56 PM
