1997 Toyota Camry REAR BRAKE HUB
1997 TOYOTA CAMRY
350,000 MILES • 4 CYL • 2WD • AUTOMATIC
SHAKERAG
HOW DO I TAKE OFF THE REAR BRAKE HUB, I CAN CHANGE OUT THE SHOES
Jun 28, 2008 at 10:37 AM
KHLOW2008
  • 41,814 POSTS
Hi SHAKERAG,
The hub are tightly fitted onto the centre seats so you need to pull it out by knocking it loose. Some rust remover helps.
If you are unable to get it loosened up, use 2 pcs of 8 X 1.25 metric bolt to bolt on the 2 small threaded hole to pull it out.
CAUTION : DO NOT use excessive force and do it evenly to prevent the drum from distortion.
Jun 28, 2008 at 7:40 PM
