1997 Toyota Camry Power Steering Hose
109,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHANNAFAST
My power steering hose is leaking. I am a widow and I ordered the hose from O'reilly's and it will be here in the morning. I was wondering if this was something I could have a friend change? He is mechanically inclined but is it difficult and if it is, how much should I pay a mechanic to do this? Thank you.
Dec 30, 2008 at 8:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Labor costs for replacing the power steering hose should be around $75. This may change depending on location of repairs.
Replacing the hose is not very difficult, but accessing the hose will be the biggest issue. He/she may have to remove other components such as vacuum hoses, fender aprons, drive belt etc.. If access is easy and components do not need removed then removal/installation should be a breeze.
Hope this helps..
Thanks for using 2carpros.com!
Dec 30, 2008 at 11:21 AM
