1997 Toyota Camry motor mounts
BPATE1
Engine Mechanical problem
1997 Toyota Camry 4 cyl Two Wheel Drive Automatic
I had the crankshaft replaced and the engine works fine now, however the car vibrates at all speeds it did not do this before the mechanic says it is the motor mounts that the car is 14 years old and when he took the engine out it took the weight off of the mounts and because they are old when he reinstalled the engine it nows vibrates
Aug 2, 2010 at 12:23 AM
FORDRACING24
  • 65 POSTS
Open your hood and have someone else start the car, if the engine moves alot it's the motor mounts. the top motor mount is on the passenger side rear of the engine, it looks like a dogbone as it twists, check it for cracks, if it's cracked the other mounts are likely cracked.
Aug 3, 2010 at 1:59 AM
