Drive the front end of the Toyota Camry onto two lift ramps and apply the parking brake to keep the Camry from moving while you are working.
Place the floor jack under the engine. Raise the floor jack up to the bottom of the engine. Use the floor jack to slightly raise the engine to take weight off of the motor mounts.
Get under the Camry and locate the motor mounts. Use the ratchet set to remove the metal bolt in the center of the motor mounts.
Pull the metal bolt from the motor mounts. Pull the motor mounts out of the fitting. Clean out any debris from the fitting with your hand.
Insert the new motor mounts into the fitting. Insert the metal bolts into the center of the new motor mounts. Tighten the new motors mount using the ratchet set.
SPONSORED LINKS
Wednesday, September 22nd, 2010 AT 9:30 PM
