1997 Toyota Camry leaking
DODGER69
  • 1997 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 201,000 MILES
In the passenger floor board water leaks when I turn a corner. I noticed it is leaking from a blower near the condensation trap. What can I remove to fix
Tuesday, August 17th, 2010 AT 1:59 PM
  • 110,052 POSTS
That is from the AC. Under the hood on the passanger side of the firewall, you will see a black rubber hose pointing toward the road. Check to see if it is plugged near the end.
Let me know what you find.
Thursday, August 19th, 2010 AT 9:50 PM
