1997 Toyota Camry KEY IN IGNITION WON'T TURN
1997 TOYOTA CAMRY
75,000 MILES • 6 CYL • FWD • AUTOMATIC
SHELUCRE
THE KEY IN THE IGNITION WON'T TURN
Apr 5, 2009 at 12:18 PM
Is your battery good? if so you have a problem with the shift interlock system.
Apr 5, 2009 at 12:46 PM
WILLIAM OLIVER
  • 25 POSTS
replace the ignition switch wich is about 100 $ part at the dealer plus labor
Apr 7, 2009 at 12:40 PM
