What are the steps to install a new hood on a 1997 camry. Any help with pictures would be really great ? Thanks !.
Aug 7, 2010 at 9:54 AM
✓Experienced Mechanic
To replace the bonnet (hood) undo the plastic washer hose and place towel under the bonnet at the fire wall end so as not to scratch the paint, support the bonnet (not heavy) and undo the 10mm bolts on the hinge, let it sit on the towel on one side and do the same on the other hinge, with both undone with a helper lift clear.
