I got a message back from my first question about a steering problem from racefan966. The car is making a loud grinding noise in both directions that you turn. it also does not have a complete turning radius. It is not making any clicking noises. Racefan966 suggested it might have something to do with the cv axles or the hub assembly. What are those? A friend said it might be a heat shield that is coming loose? The car sounds like something is loose when you go over a bump.I don't know if this is how to get back to racefan966.
Thanks, Frannie Newbold
Nov 13, 2008 at 3:35 AM
