How can I fix my turning signals from clicking so fast? If it is a fuse, wich certain fuse do I replace?
Mar 3, 2008 at 2:56 PM
✓Experienced Mechanic
Hi there make sure all the globes are working and are the correct voltage and wattage, if ok, replace the indicator flasher control unit, you should hear it clicking under the dash with the indicators on.
