I took it to the shop and the engine scan had PO305, engine misfire and PO135, faulty bank 1 O2 sensor heat failure. Their road test had no engine problem and they replaced an O2 sensor.
When I got it back it ran fine a few days. Yesterday, after I drove it somewhere I got in to start it and the engine sound and vibration came back. I drove it home about 5 miles and it seemed as if it didn’t have much power. This morning I started it and it was fine.
So it seems to happen once the engine is warmed up. The engine is a 1MZ-FE.
Could it be the IAC valve?
Thanks
SPONSORED LINKS
Tuesday, March 17th, 2009 AT 10:22 AM
