1997 Toyota Camry electric seat
1997 TOYOTA CAMRY
89,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMES PAK
The passenger's electric seat moves up/down forward/backward fine; however, back of the seat lays down but only the right side comes back up. As you tries to raise the back, it twists because only the right side comes up. Any suggestions as to how to fix this problem?
Feb 19, 2008 at 2:06 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the seat frame or pivot might be broken. You will have to remove the seat cover and see if it is broken
Feb 19, 2008 at 6:57 AM
