1997 Toyota Camry driver side window
190,000 MILES • 4 CYL • FWD • AUTOMATIC
ABSFORDAZE
Passenger side window does not work. All other window work
May 16, 2008 at 8:53 AM
MASTERTECHTIM
  • 4,750 POSTS
check for power and ground at the window motor and if you have power and ground when you put the switch down then replace the window motor
May 16, 2008 at 8:54 AM
