1997 Toyota Camry Draging brakes
16,000 MILES • 6 CYL • FWD • AUTOMATIC
FAST FRANK
I just completed a brake job and changed all calpers, pads and rotors. I bled the brakes and I had no pedal. I replaced the master cylinder and then I got a good pedal. I took the car out for a test run and everything was OK. The next day I was going to work and started to go on the highway and the car started to shake. I pulled over and the brake pedal was very hard. I started again and then the shaking went away and the pedal was back to normal. This has happened other times and I do not know what the problem is.
Apr 21, 2009 at 10:18 AM
  • 75,988 POSTS
DRAGGING BRAKES May create a steering pull and/or increased fuel consumption. Caused by weak or broken retracting springs on drum brakes, a jammed or corroded caliper piston, a floating caliper with badly corroded mounting pins or bushings (uneven pad wear between the inner and outer pads is a clue here), overextended drum brake self-adjusters or a sticky or frozen emergency brake cable.
Apr 21, 2009 at 10:27 AM
