1997 Toyota Camry Brakes
RREGINALD
Brakes problem
1997 Toyota Camry 4 cyl Front Wheel Drive Automatic 70k miles
Is it normal for my brake(s) pedal to occasionally go all the way to the floor rendering me to press them again in order for my car to come to a complete stop? As if I have to pump them before I stop.If not, What needs to be repaired and How much would it cost? 1997 Camry
Jan 11, 2010 at 3:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
could be many things , an inspection of the brake system is needed to find the correct culprit. most likely cause for this issue though is a faulty brake booster or bad vacuum at the booster.
Jan 11, 2010 at 3:36 PM
