1997 Toyota Camry AC Water Leak Under Floor Board
1997 TOYOTA CAMRY
115,000 MILES • 4 CYL • FWD • AUTOMATIC
ODUCKS
The carpet/floor on the front passenger side of my 97 Camry gets soaking wet when the AC is on. Is there a drainage line under the carpet. Can it be accessed by removing the carpet. Any help for fixing the problem is appreciated. Thanks
Jun 7, 2009 at 5:17 AM
BILLYMAC
  • 2,204 POSTS
Hi yes there is a drain line it goes through the firewall and drains on the ground
on the right side of the firewall`.
probably is plugged up air pressure is good for solveing this prob or if not avail a coat hanger will open it. or possibly the part under the dash you can see may be brokes..good luck billymac
Jun 8, 2009 at 10:19 AM
ODUCKS
Jun 8, 2009 at 3:19 PM
