1997 Toyota Camry ABS Problem
154,000 MILES • 4 CYL • FWD • AUTOMATIC
SANDY1591
My question is about my ABS system---Right after I had the front CV joints replaced the ABS system started to act up. It made the car move from side to side and it was very jerky. My thought is that it has to be a sensor only because the problem developed after the CV joint replacement. In the mean time so I can still drive the car I removed the fuse for the computer so it won't engage. Any thoughts about what it might be? I have cleaned the sensor but it didn't fix the problem. Any insight would be great.
Jan 30, 2008 at 11:52 AM
BMRFIXIT
  • 19,053 POSTS
[quote:3f1d0c8063="Sandy1591"]Suspension problem
1997 Toyota Camry 4 cyl Front Wheel Drive Automatic 154000 miles
My question is about my ABS system---Right after I had the front CV joints replaced the ABS system started to act up. It made the car move from side to side and it was very jerky. My thought is that it has to be a sensor only because the problem developed after the CV joint replacement. In the mean time so I can still drive the car I removed the fuse for the computer so it won't engage. Any thoughts about what it might be? I have cleaned the sensor but it didn't fix the problem. Any insight would be great.[/quote:3f1d0c8063]
check the new axle that you just replaced make sure it has the ABS ring on it
Jan 30, 2008 at 11:55 AM
