1997 Toyota Camry ABOUT BRAKE BLEEDING
1997 TOYOTA CAMRY
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
HAYRI1408
hi my name is hayri i have checked the process of replacing front and rear brakes pads. after the installation is it necessary to bleed the hydraulic system? if you could please answer this i would greatly appreciate it.
thank you
Dec 10, 2007 at 3:09 PM
  • 31,937 POSTS
Hi there,
If you have compressed the piston back into the caliper with out opening the bleeders, there is no need to re bleed. If you have opened the hydraulic system you will have to bleed the brakes. To bleed have an assistant press the brakes open the bleeder at the caliper and allow air / fluid to escape. Close bleeder and release pedal. Do this until there us no visible air bubbles, bleed each brake and don't let the fluid fall below 1/4 full in the reservoir. There is no adjustment on disc brakes. Here is a video and guide below to help you bleed the brake system correctly.
https://youtu.be/w7gUsj2us0U
and
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
and
https://youtu.be/WDxvEQrMkBg
Mar 11, 2021 at 4:46 AM
