My 1997 toyota camry will start but will not take fuel and idles rough. Whats the problem?
Friday, May 21st, 2010 AT 11:16 AM
MECHANIC
Hi jhonestop, Welcome to 2carpros and TY for the donation
Check the fuel pressure if its within specs and get back with the readings. Possible causes could be the idle air control valve, EGR/PCV valves to include the throttle posiiton sensor and airflow meter
