1997 Toyota Camry
EDDIEMOORE
Electrical problem
1997 Toyota Camry 4 cyl Two Wheel Drive Automatic 357K miles
97 Camry LE, Driver's window motor burned up, window won't move. Any thoughts as to how to get window up until I can replace motor?
Mar 17, 2009 at 1:32 PM
BMRFIXIT
  • 19,053 POSTS
Motor control the movement
if its burnt have to separate and pull window up and secure back on
this is why its just as easy to replace the motor
or try and tap on the motor as you holding the switch up
Mar 17, 2009 at 1:42 PM
