1996 Toyota Camry wiper nozzles
1996 TOYOTA CAMRY
335,245 MILES • 6 CYL • FWD • AUTOMATIC
MIKEO412
My nozzles are blocked. Have replaced the whole system from the reservoir to the hoses. Apparently the original motor had a filter screen that fell apart and clogged everything. now have fluid coming out fine at hoses but when i hook them to the sprayer nozzles it just dribbles out. tried clearing them with a pin and compressed air but no luck. Purchased an aftermarket set of nozzles, my question is how do i get the old ones off. would rather not just try breaking them out, but i can't see any clips or such and the chiltons manual i have doesn't even mention them. please help as i am tired of reaching out the window to throw water on the windshield so i can see. Have used you guys beforwe with good results.
Thanks
Mike
Mar 4, 2010 at 11:10 AM
MMPRINCE4000
  • 8,548 POSTS
They "snap" in, but generally if original they will break, you can get new ones from Toyota for $16 each or so.
Mar 6, 2010 at 12:25 AM
MIKEO412
i have the replacements, just wondering how to get the old ones out of my hood without damaging the sheet metal or anything. thanks!
Mar 9, 2010 at 4:49 AM
MMPRINCE4000
  • 8,548 POSTS
Use a pair of needle nose pliers and break them if you have to. Do this from under hood.
Mar 9, 2010 at 10:25 PM
