At tiems thje vehicle the temperature gage reads hots and then the radiator begins to discharge thru the overflow thank for no real reason. Then the radiator is completely empty of all coolant. The radiator was replace witha used one from a 1992 Toyota Camry. What could cause this? The water pump, the radiator itself or the overflow tank?
2. Wiper will not turn off once they are turn on, unless you disconnect the wiper motor. Then it reset, but if you turn it on again then it starts all over.
May 11, 2009 at 10:50 AM
