1996 Toyota Camry Transmission question
TYKO17
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • MANUAL
  • 240 MILES
Hi I was wondering if I could get any advice about my transmission. The problem is that I cant get into first or second gear. When I put it into first gear it feels like it is in third. I have noticed a clicking sound when I move the shifter left to right in neutral, and also if I am in third gear I can move the shifter from left to right as if I were in neutral.
Wednesday, May 13th, 2009 AT 6:49 PM
  • 31,937 POSTS
Hi there,
This may be a fault with the two selector cables, I would check that the "C"clip that hold the cables in place at the gear box end are still intact and also check the gear lever quadrant as well for a fault.
Mark (mhpautos)
Wednesday, May 13th, 2009 AT 6:55 PM
TYKO17
I checked the cables they seem fine and the clips but what do you mean by the quadrant thanks.
Wednesday, May 13th, 2009 AT 7:14 PM
  • 31,937 POSTS
Hi there,
Thats the gear stick and the mechanism that selects the cable.
Mark (mhpautos)
Wednesday, May 13th, 2009 AT 7:21 PM
