1996 Toyota Camry temperature gauge running cold
145,000 MILES • 4 CYL • FWD • MANUAL
1996CAMRY
8 days ago my engine overheated. The gauge was working at that time. The mechanic replaced the thermostat and it worked fine for 6 days. Then the gauge began reading cold, occasionally to the middle for a few seconds, then returning to cold. After 2 days of this, the check engine light came on and stayed on. Any ideas? Thanks.
Mar 23, 2009 at 8:16 AM
DOCFIXIT
  • 18,828 POSTS
Have codes read that will tell what put light on. Also temp sender may have been damaged in overheat.
Mar 23, 2009 at 8:27 AM
