1996 Toyota Camry Sun roof stuck open
200,000 MILES • 6 CYL • FWD • AUTOMATIC
IAC
My sun roof all the sudden stopped working. I was going to check the fuse but I'm not to sure which one to remove. Are the windows and sun roof on the same fuse?
Aug 17, 2009 at 6:54 AM
STEVEW84
  • 673 POSTS
First check some fuses first. Wiring diagram show 3 fuses on sunroof circuit. 10a(gauge), 30a(power), 20a(dome). On your fuse panel cover it will should say what they are. I would just all the fuses though. If they are ok then you have to pull the headliner down to check the sunroof.
Aug 18, 2009 at 5:35 AM
