1996 Toyota Camry noise when I brake
194,000 MILES • 4 CYL • FWD • AUTOMATIC
TRANSPLANTED2SC
When I brake at a light there is a noise that is very loud. Hard to describe, not a squeak or scrape. New brakes and rotors were put in and the noise is still there. Car stops fine but the noise makes me nervous. I was thinking that it was the ABS although there is no light that comes on. I am at a loss. Took it to the local mechanic and his response was " beats me- never heard that before"
Jan 30, 2009 at 7:25 AM
  • 31,937 POSTS
Hi there,
You better take it to a mechanic the want to help, that is a very poor attitude, it will be a simple job to listen and locate this fault, it just may be that the brakes need bedding in or that something is loose may be an anti rattle clip? find a mechanic that will inspect rather that fob it off.
Mark (mhpautos)
Jan 30, 2009 at 8:41 AM
RAUL RIZZUTI
  • 8 POSTS
The problem is definitely the ABS
Jan 31, 2009 at 10:38 PM
