1996 Toyota Camry noise when I brake
TRANSPLANTED2SC
  • 1996 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 194,000 MILES
When I brake at a light there is a noise that is very loud. Hard to describe, not a squeak or scrape. New brakes and rotors were put in and the noise is still there. Car stops fine but the noise makes me nervous. I was thinking that it was the ABS although there is no light that comes on. I am at a loss. Took it to the local mechanic and his response was " beats me- never heard that before"
Friday, January 30th, 2009 AT 3:25 PM
  • 31,937 POSTS
Hi there,
You better take it to a mechanic the want to help, that is a very poor attitude, it will be a simple job to listen and locate this fault, it just may be that the brakes need bedding in or that something is loose may be an anti rattle clip? Find a mechanic that will inspect rather that fob it off.
Mark (mhpautos)
Friday, January 30th, 2009 AT 4:41 PM
RAUL RIZZUTI
  • 8 POSTS
The problem is definitely the ABS
Sunday, February 1st, 2009 AT 6:38 AM
