Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Engine
Symptoms
Compression
1996 Toyota Camry Low compression
1996 TOYOTA CAMRY
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
DADHANNEY
MEMBER
1 POST
Does low compression in each cylinder mean timing belt problem?
Oct 6, 2009 at 7:54 AM
DOCFIXIT
Experienced Mechanic
That's a possibllity does engine run? What are comp. readings? Think there is an view port in T cover put crank at TDC then see cam mark. see diagram
Oct 6, 2009 at 8:14 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
