The left rear door will no longer lock with the power lock. However, the latch moves as it always does and it still locks by hand by flipping the lock switch. This makes no sense to me because it moves the same distance with the power switch as it does by hand. Anyway, the problem I have is removing the Bezel from the swich/handle mechanism. The haynes manual shows a screwdriver under one side, flipping out the whole bezel. I have tried various width screw drivers and even a scraper blade but it acts as though there is a screw or something holding it in. There is no visible sign of a screw or any hold down mechanism. I do not want to break this Bezel as I am sure it costs more than the job I am trying to fix. Any answer for me? Thank you
Dec 27, 2009 at 1:41 PM
