1996 Toyota Camry Left axel outer boot
45,000 MILES • 6 CYL • FWD • AUTOMATIC
JMAR164
My service station indicated the left axel outer boot is broken and will cost $199.95 torepair.
My question is this: Since I don't know what an outer booti is, is this a valid repair that needs to be done? does it have tobbe done immediately? What could happen if not done?
Thank you
Joe Martello jmar164@aol.com
Sep 26, 2008 at 6:25 AM
  • 55,604 POSTS
Hello, yes 199.00 for a boot replacement is normal, this repair must be done to avoid failure and should be done ASAP to avoid a break down. The boot covers the drive axle cv joint and keeps water and dirt out.
Thanks for using 2carpros.com :-)
Sep 30, 2008 at 8:37 AM
