1996 Toyota Camry how to install driveaxles
1996 TOYOTA CAMRY
RBURGESS
Drive Train Axles Bearings problem
1996 Toyota Camry 4 cyl Front Wheel Drive Automatic
how do you remove and install driverside axle
Jun 5, 2008 at 4:43 AM
KHLOW2008
  • 41,814 POSTS
Hi rburgess,
Remove the following
1. Wheel.
2 Driveshaft lock nut.
3. Steering tie rod end ball joint and stabilizer link.
4. Brake caliper assy.
5. Lower arm ball joint
6. Strut bolts.
Push driveshaft out of axle assy and it is out.
Jun 5, 2008 at 5:43 AM
