1996 Toyota Camry heater fan controls
1996 TOYOTA CAMRY
120,000 MILES • 4 CYL • FWD • AUTOMATIC
EPL01
96 Toyota Camry LE 2.2 ltr auto trans.
fan controls, heater, defroster all just quit working. Am thinking it is a fuse issue and went to check fuses. Can't find listing in manual for fuse related to heater,fan, defroster controls. Car seems to drive fine and all other electrical systems seem to be working properly. Might these controls fall under a different fuse, or where would the fuse for the fan controls be located. If not a fuse, what might be a possible solution. Am not an idiot as far as cars go, but am awful confused with this issue.
Dec 14, 2009 at 2:34 PM
BMRFIXIT
  • 19,053 POSTS
If I recall correct heater fuse is at the right side kick panel
disconnect blower motor ,start engine ,place heater fan at high ,check for power and ground
Dec 15, 2009 at 12:02 PM
