Hi there,
The fuel pump is an in-tank type pump, to access it, remove the rear seat base, there is a cover plate, remove and pump access is there. Disconnect battery, De pressure fuel system, remove and ident fuel lines (pressure and return) disconnect electrical plug, remove screws and carefully with draw, pump is mounted in a cradle that holds the fuel level sender so be careful with drawing from tank.
Mark (mhpautos)
Dec 19, 2007 at 7:32 AM
