1996 Toyota Camry FUEL PUMP
80,000 MILES • 4 CYL • FWD • AUTOMATIC
MILEWSKI
HOW DO I CHANGE OUT MY FUEL PUMP?
Dec 19, 2007 at 1:39 AM
  • 31,937 POSTS
Hi there,
The fuel pump is an in-tank type pump, to access it, remove the rear seat base, there is a cover plate, remove and pump access is there. Disconnect battery, De pressure fuel system, remove and ident fuel lines (pressure and return) disconnect electrical plug, remove screws and carefully with draw, pump is mounted in a cradle that holds the fuel level sender so be careful with drawing from tank.
Mark (mhpautos)
Dec 19, 2007 at 7:32 AM
