1996 Toyota Camry Fuel Gauge
1996 TOYOTA CAMRY
JITUKALI
  • 7 POSTS
1996 Toyota Camry 4 cyl Two Wheel Drive Automatic
The Fuel Gauge on my camry has stopped working
what trigger the gauge to work. is it a fuse or relay
what the fix for that
Thanks in advance
Nov 23, 2008 at 12:41 PM
DAVE H
  • 13,384 POSTS
FUEL GAUGE & WARNING LIGHT
Fuel Gauge & Wiring Harness Operational Test
Unplug fuel tank sending unit connector. Turn ignition on. If fuel gauge indicates EMPTY, go to next step. If fuel gauge does not indicate EMPTY, repair short circuit in wiring harness. See WIRING DIAGRAMS .
Connect a 12-volt, 3.4-watt test light between appropriate terminals of sending unit wiring harness connector. See Fig. 1 . See FUEL GAUGE & HARNESS TEST table.
With ignition on, test light should flash and gauge needle should move toward FULL. If test light does not flash and gauge needle does not move, check wiring harness for open circuit. Repair or replace as necessary. If wiring harness checks good, replace fuel gauge.
ModelSending Unit Connector Terminals No.
Camry1 & 3
Nov 23, 2008 at 1:21 PM
