The cost of repair always depends on where you take it, what all has to be done, and if your mechanic is honest or not. If you have to get two new axles, it could cost you almost $1000. If you can do it yourself, each axle will be about $150. I could walk you through it step by step... It is a VERY easy job to perform. Save your money for the alignment that you WILL need afterwards.
Feb 25, 2010 at 3:59 AM
