1996 Toyota Camry correct idle speed when idled? car vibrat
DVDDELIA75
Engine Performance problem
1996 Toyota Camry 4 cyl Front Wheel Drive Automatic
car vibrates when idled had all motor mounts replaced but still vibrates whats the correct idle speed when idled and should I raise it ,because when the rpms go higher it stops vibrating
Feb 21, 2009 at 12:40 PM
  • 75,988 POSTS
Idle speed should be 700-800 rpm.
Feb 21, 2009 at 3:24 PM
KRONOSMOAT
Did you find an adjustment? My 94 4cyl automatic, is idling at 500 rpms, no other problems other than the vibrating and am still looking for an adjustment.
Thanks
Apr 4, 2009 at 5:34 AM
